PCA.1S.650.CTLC52
PCA.1S.650.CTLC52
    LEMO(雷莫)
    PCA.1S.650.CTLC52
PCA.1S.650.CTLC52 数据手册
PCA.1S.650.CTLC52 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1S Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.20 - 5.20 mm Status active Matching parts FFA.1S.650.CTAC52 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PCA*: Free receptacle, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 19.85 g Performance Configuration 1S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.034in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A C L S2 mm. 11.9 6.2 40.5 8.5 in. 0,47 0,24 1,59 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.ZZZ.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PCA.1S.650.CTLC52 价格&库存
很抱歉,暂时无法提供与“PCA.1S.650.CTLC52”相匹配的价格&库存,您可以联系我们找货
