EPL.0S.650.NTN
EPL.0S.650.NTN
    LEMO(雷莫)
    插件
    EPL.0S.650.NTN
EPL.0S.650.NTN 数据手册
EPL.0S.650.NTN www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 0S Termination type Female print PCB IP rating 50 AWG wire size 0.00 - 0.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FFA.0S.650.CLAC17 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EPL*: Elbow receptacle for printed circuit Keying Circular, female Housing Material Brass (nickel plated [SAE AMS QQ N 290]) collet and crimping tube, brass (chrome plated [SAE AMS 2460]) collet nut Weight 8.02 g Performance Configuration 0S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Test Voltage(kV rms) 1.2 Cable type: RGT 178, RGT 174 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A H I L N d mm. 8.8 13 9 23.6 9 5.08 in. 0,35 0,51 0,35 0,93 0,35 0,20 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.0S.M09.4 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
EPL.0S.650.NTN 价格&库存
很抱歉,暂时无法提供与“EPL.0S.650.NTN”相匹配的价格&库存,您可以联系我们找货
EPL.0S.650.NTN
  • 100+294.60037100+38.11106
