PSA.0E.250.CTLC50
PSA.0E.250.CTLC50
    LEMO(雷莫)
    PSA.0E.250.CTLC50
PSA.0E.250.CTLC50 数据手册
PSA.0E.250.CTLC50 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 0E Termination type Female solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 4.60 - 5.00 mm Status active Alternative part PSA.0E.250.CTLK50 Matching parts FFA.0E.250.CTAC50 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 18.29 g Performance Configuration 0E.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1 mm (0.039in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 0.25 * f/GHz Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S2 S3 e mm. 18 19.5 5.5 34 4 12.5 8 17 M14x1.0 in. 0,71 0,77 0,22 1,34 0,16 0,49 0,31 0,67 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0E.ZZZ.PA080 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 158480 PUR Black 158490 PVC Black CCX.50.088.292495N PVC Black CCX.50.RG5.8CU50N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.0E.250.CTLC50 价格&库存
很抱歉,暂时无法提供与“PSA.0E.250.CTLC50”相匹配的价格&库存,您可以联系我们找货
