XRG.00.250.NTN
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
00
Termination type
Female print PCB
IP rating
50
AWG wire size
0.00 - 0.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
XR*: Elbow receptacle, fixing nut for printed circuit, short shell, threaded-fixing (back
panel mounting)
Keying
Circular, female
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces
Weight
4.26 g
Performance
Configuration
00.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
4 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Printed Circuit Board)
Contact Dia.: 0.7 mm (0.028in)
Test voltage: 2.1 kV (rms)
R (max): 6.1 mOhm
Vtest: 2100 V (AC), 3000 V (DC)
Impedance: 50 Ohm
VSWR: 1.09 + 0.11 * f/GHz
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Others
Endurance (Shell): 5000 mating cycles
F ret (min): 100 N
Salt Spray Corrosion: >144 hr
DRAWINGS
Dimensions
A
E
I
L
M
P
Thread(min)
e
mm.
10
1.3
7
14
2.5
7
3.2
M7x0.5
in.
0,39
0,05
0,28
0,55
0,10
0,28
0,13
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“XRG.00.250.NTN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+342.801221+44.00262
