FFB.1S.250.CLAC32
FFB.1S.250.CLAC32
    LEMO(雷莫)
    FFB.1S.250.CLAC32
FFB.1S.250.CLAC32 数据手册
FFB.1S.250.CLAC32 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.20 - 3.20 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFB*: Straight plug, cable collet and safety locking ring Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 15.81 g Performance Configuration 1S.250 : 1 Coax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 1.6 mm (0.063in) Bucket Dia.: 1.4 mm (0.055in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.23 * f/GHz Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 45 34 8.5 in. 0,47 1,77 1,34 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.ZZZ.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 17420 PVC Black 17450 COPOLYMER Black 18700 PTFE White 18800 PTFE White 31600 PTFE Brown CCX.50.RG0.58AU14B FEP White CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFB.1S.250.CLAC32
PDF文档中的物料型号为FFB.1S.250.CLAC32。
器件是一个直插头、电缆夹紧和安全锁定环的同轴电缆连接器,具有圆形的男性键槽。
外壳材料为镀铬黄铜和镍镀黄铜的锁紧套和中件。
器件重量为15.81克。
技术细节方面,配置为1S.250,包含1个50欧姆同轴电缆。
绝缘体材料为PEEK,额定电流为12安培。
接触类型为50欧姆同轴焊接触,接触直径和桶直径分别为1.6毫米和1.4毫米。
电气测试参数包括3000伏交流或4200伏直流的电压测试、50欧姆的阻抗、1.01加上0.23乘以f/GHz的电压驻波比(VSWR)。
适用电缆类型包括RG 178 B/U、RG 196 A/U等。
其他特性包括5000次配对周期的耐久性、-55°C至+250°C的工作温度范围、最大95%的湿度、15g的振动测试、100g的冲击抵抗力,以及至少75dB(10 MHz)和至少40dB(1 GHz)的屏蔽效能。
封装信息包括推荐使用的LEMO工具和电缆,如DCD.1S.ZZZ.PA085扳手和多种类型的电缆,例如PVC、COPOLYMER、PTFE、FEP材料的电缆。
LEMO产品提供“按现状”服务,不提供任何明示、暗示或法定的保证,包括准确性、完整性或安全性。
用户需为其使用LEMO组件的产品和应用负全责。
FFB.1S.250.CLAC32 价格&库存
很抱歉,暂时无法提供与“FFB.1S.250.CLAC32”相匹配的价格&库存,您可以联系我们找货
