FLA.00.250.NTAD56
FLA.00.250.NTAD56
    LEMO(雷莫)
    FLA.00.250.NTAD56
FLA.00.250.NTAD56 数据手册
FLA.00.250.NTAD56 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 00 Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 5.10 - 5.50 mm Status active Matching parts ERA.00.250.NTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FLA/D*: Elbow plug with oversize cable collet Keying Circular, male Housing Material Brass (nickel plated [SAE AMS QQ N 290]) shell, collet nut, latch sleeve and mid pieces Weight 7.27 g Performance Configuration 00.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 4 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.6 mm (0.024in) Test voltage: 2.1 kV (rms) R (max): 6.1 mOhm Vtest: 2100 V (AC), 3000 V (DC) Impedance: 50 Ohm VSWR: 1.09 + 0.11 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 Others Endurance (Shell): 5000 mating cycles F ret (min): 100 N Salt Spray Corrosion: >144 hr DRAWINGS Dimensions A D H L M S2 S3 mm. 9 8.6 24 17.5 9.5 7 8 in. 0,35 0,34 0,94 0,69 0,37 0,28 0,31 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.00.ZZZ.PA050 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FLA.00.250.NTAD56 价格&库存
很抱歉,暂时无法提供与“FLA.00.250.NTAD56”相匹配的价格&库存,您可以联系我们找货
