FLA.1S.275.CTAC52Z
FLA.1S.275.CTAC52Z
    LEMO(雷莫)
    FLA.1S.275.CTAC52Z
FLA.1S.275.CTAC52Z 数据手册
FLA.1S.275.CTAC52Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.20 - 5.20 mm Status NRND Matching parts ERA.1S.275.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FLA*: Elbow plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 25.46 g Performance Configuration 1S.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 10 Amps Specifications Contact Type: Coaxial 75 Ohm (Solder) Contact Dia.: 1.3 mm (0.0512in) Bucket Dia.: 1.1 mm (0.0432in) Vtest: 2400 V (AC), 3300 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.08 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A H L M S1 S2 mm. 16 28.5 26.5 15.5 10 8.5 in. 0,63 1,12 1,04 0,61 0,39 0,33 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 158480 PUR Black 158490 PVC Black CCX.50.088.292495N PVC Black CCX.50.RG5.8CU50N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FLA.1S.275.CTAC52Z 价格&库存
很抱歉,暂时无法提供与“FLA.1S.275.CTAC52Z”相匹配的价格&库存,您可以联系我们找货
