FFA.1S.650.CTAC62Z
FFA.1S.650.CTAC62Z
    LEMO(雷莫)
    FFA.1S.650.CTAC62Z
FFA.1S.650.CTAC62Z 数据手册
FFA.1S.650.CTAC62Z www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1S Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 5.20 - 6.20 mm Status active Matching parts ERA.1S.650.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 13.68 g Performance Configuration 1S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 42.5 31.5 9 in. 0,47 1,67 1,24 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1B.ZZZ.PA090 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1S.650.CTAC62Z 价格&库存
很抱歉,暂时无法提供与“FFA.1S.650.CTAC62Z”相匹配的价格&库存,您可以联系我们找货
