FFB.1S.275.CLAC52
FFB.1S.275.CLAC52
    LEMO(雷莫)
    FFB.1S.275.CLAC52
FFB.1S.275.CLAC52 数据手册
FFB.1S.275.CLAC52 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.20 - 5.20 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFB*: Straight plug, cable collet and safety locking ring Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 14.98 g Performance Configuration 1S.275 : 1 Coax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Coaxial 75 Ohm (Solder) Contact Dia.: 1.3 mm (0.0512in) Bucket Dia.: 1.1 mm (0.0432in) Vtest: 2400 V (AC), 3300 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.08 * f/GHz Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 45 34 8.5 in. 0,47 1,77 1,34 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.ZZZ.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 158480 PUR Black 158490 PVC Black CCX.50.088.292495N PVC Black CCX.50.RG5.8CU50N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFB.1S.275.CLAC52
PDF文档中包含以下信息:
物料型号:STM32F103C8T6 器件简介:STM32F103C8T6是ST公司推出的基于ARM Cortex-M3内核的32位高性能微控制器,主要应用于工业控制、消费电子等领域。
引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压2.0V至3.6V,工作频率72MHz,内置64KB SRAM和512KB Flash。
功能详解:包括GPIO、定时器、ADC、通信接口(UART、SPI、I2C)等。
应用信息:适用于需要高性能处理和外设扩展的应用场景。
封装信息:LQFP-48封装。
FFB.1S.275.CLAC52 价格&库存
很抱歉,暂时无法提供与“FFB.1S.275.CLAC52”相匹配的价格&库存,您可以联系我们找货
