ROHS COMPLIANT
REVISION HISTORY
DESCRIPTION
REV
PRODUCT DATA DRAWING
DCN 37960
DATE
APPROVED
01/11
STW
.262 6.65
RP
.110 2.79
SMP MALE FD
.137 3.48
.015±.001 0.38±0.03
MATERIAL:
BODY &
BUSHING:
.217 5.51
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
CENTER PIN &
OUTER RING:
KOVAR PER ASTM-F15
GLASS:
CORNING #7070
2X .043 1.09
WIDE SLOT
.050 1.27
FINISH:
BODY &
BUSHING:
CENTER PIN &
OUTER RING:
.040 1.02
10-32 UNF-2A
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
GOLD PER ASTM B 488, TYPE I,
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
VSWR:
TEMP. RATING:
50 OHMS
DC TO 26.5 GHz
1.25:1 DC TO 18.0 GHz
1.35:1 DC TO 26.5 GHz
-65 C TO +165 C
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
FED 01/18/11
CHECKED:
APPROVED:
STW 01/18/11
STW 01/18/11
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMP MALE, THREADED
HERMETIC FD SHROUD FEED
THROUGH CONNECTOR
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 12:1
1279-4001
SHEET 1 OF 1
很抱歉,暂时无法提供与“1279-4001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+855.7278850+110.91863
