FFA.1S.275.CTAC62
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1S
Termination type
Male solder Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
5.20 - 6.20 mm
Status
active
Matching parts
ERA.1S.275.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
13.41 g
Performance
Configuration
1S.275 : 1 Coax (75 Ohm)
Insulator
T: PTFE
Rated Current
10 Amps
Specifications
Contact Type: Coaxial 75 Ohm (Solder)
Contact Dia.: 1.3 mm (0.0512in)
Bucket Dia.: 1.1 mm (0.0432in)
Vtest: 2400 V (AC), 3300 V (DC)
Impedance: 75 Ohm
VSWR: 1.02 + 0.08 * f/GHz
Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
12
42.5
31.5
8.5
in.
0,47
1,67
1,24
0,33
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1S.ZZZ.PA085
2/3
Cables
159580
PVC
Black
62000
PVC
Black
CCX.50.080.297538N
PVC
Black
CCX.50.RG0.58AU61J
PVC
Yellow
CCX.75.RG0.59BU62N
PVC
Black
CCX.93.RG0.62AU62N
PVC
Black
3/3
很抱歉,暂时无法提供与“FFA.1S.275.CTAC62”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+532.228211+68.65880
- 10+473.0138810+61.02000
