EPA.0S.250.NTN
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
0S
Termination type
Female print PCB Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FFA.0S.250.NTAC42
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EPA*: Fixed receptacle for printed circuit
Keying
Circular, female
Housing Material
Brass (nickel plated [SAE AMS QQ N 290]) collet and crimping tube, brass (chrome plated
[SAE AMS 2460]) collet nut
Weight
4.65 g
Performance
Configuration
0S.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Coaxial 50 Ohm (PCB)
Contact Dia.: 0.9 mm (0.04in)
Bucket Dia.: 1 mm (0.04in)
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.02 + 0.25 * f/GHz
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
B
C
K
L
N
mm.
9
0.7
0.8
3
19.5
3.5
in.
0,35
0,03
0,03
0,12
0,77
0,14
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.0S.M09.4
2/3
3/3
很抱歉,暂时无法提供与“EPA.0S.250.NTN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+333.77394100+43.38055
