FFA.1S.650.CTAC47
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
1S
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
4.20 - 5.20 mm
Status
active
Alternative part
FFA.1S.650.CTAC52
Matching parts
ERA.1S.650.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
13.29 g
Performance
Configuration
1S.650 : 1 Triax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.01 + 0.17 * f/GHz
Cable type: RGT 178, RGT 174,Belden 9222
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
12
42.5
31.5
8.5
in.
0,47
1,67
1,24
0,33
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1S.ZZZ.PA085
2/3
3/3
很抱歉,暂时无法提供与“FFA.1S.650.CTAC47”相匹配的价格&库存,您可以联系我们找货
