1711-60044-TD
1711-60044-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMAPLUGSTR50OHMEDGEMNT
1711-60044-TD 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV - .100 2.54 DCN 42335 DATE APPROVED 05/16 DAL .511 12.98 .120 3.05 .210 5.33 FOR .068" THICK BOARD .030 0.76 SOLDER .239 6.06 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 NOTES: 1. TO BE TIN DIPPED USING Sn96 SOLDER. 2. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING. FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.26, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY FREQ.RANGE: DC TO 22.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GPF 05/19/16 CHECKED: DAL 05/19/16 DAL 05/19/16 APPROVED: 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA MALE PCB EDGE LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 1711-60044-TD SHEET 1 OF 1
1711-60044-TD 价格&库存
很抱歉,暂时无法提供与“1711-60044-TD”相匹配的价格&库存,您可以联系我们找货
