1785-6001-TD
1785-6001-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMARCPTSTR50OHMPCB
1785-6001-TD 数据手册
CONFIGURATION CONTROL LEVEL: 3 ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 43089 DATE APPROVED 02/17 MAL .500 12.70 .240 .343 8.71 .157 3.99 .0505 1.28 2X .200 5.08 .202±.002 5.13±0.05 4X .0685±.0015 1.74±0.04 2X .200 5.08 MATERIAL: BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROCARBON RUBBER PER AMS 7276 .062 1.57 NOTES: 1. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) 2. TO BE TIN DIPPED USING Sn96 SOLDER 3. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING FINISH: BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .076, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: PER BOM PER BOM PERFORMANCE: IMPEDANCE: 50 OHMS PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE AFTER PLATING. 2) BREAK CORNERS & EDGES .005 R. MAX. 3) CHAM. 1ST & LAST THREADS. 4) SURFACE ROUGHNESS 63 MIL-STD-10. 5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 6) REMOVE ALL BURRS DRAWN: VB 02/09/17 CHECKED: APPROVED: MAL 02/09/17 MAL 02/09/17 E.M. SIMULATION: N/A 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA PLUG RECEPTACLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 1785-6001-TD SHEET 1 OF 1
1785-6001-TD 价格&库存
很抱歉,暂时无法提供与“1785-6001-TD”相匹配的价格&库存,您可以联系我们找货
