1789-6001
1789-6001
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMARCPTR/A50OHMPCB
1789-6001 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV B .525±.010 13.34±0.25 DCN 41836 DATE APPROVED 11/15 STW .240 6.10 2X .200 5.08 .250±.002 6.35±0.05 .0505±.0005 1.28±0.01 .578±.006 14.68±0.15 4X .040 1.02 .458 11.63 .155 3.94 MATERIAL: BODIES: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 TERMINAL: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROCARBON RUBBER PER AMS 7276 PRESS CAP: STAINLESS STEEL PER ASTM-A-240, ALLOY UNS S30400, TYPE 304 FINISH: BODIES, CONTACTS & TERMINAL: PRESS CAP: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. GOLD PER ASTM B 488, TYPE I, CODE C, CLASS .50, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VMJ 04/12/00 CHECKED: APPROVED: STW 04/13/00 STW 04/13/00 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA R/A PLUG RECEPTACLE PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 5:1 1789-6001 SHEET 1 OF 1
1789-6001 价格&库存
很抱歉,暂时无法提供与“1789-6001”相匹配的价格&库存,您可以联系我们找货
