3211-60112-TD
3211-60112-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSMD
3211-60112-TD 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 42490 DATE APPROVED 07/16 DAL .154 3.91 RP .150 3.81 .009 0.23 .067±.001 1.70±0.03 .125 3.18 .030 0.76 SOLDER .085 2.16 NOTE 2 NOTE 2 .012±.001 0.30±0.03 .028±.001 0.71±0.03 NOTE 2 MATERIAL: BODY: STAINLESS STEEL CONTACT: BERYLLIUM COPPER INSULATOR: TORLON 2X .033 0.84 NOTES: 1. 2. 3. FINISH: BODY & CONTACT: .154 3.91 GOLD OVER NICKEL MATERIAL: PERFORMANCE: FINISH: IMPEDANCE: FREQ. RANGE: VSWR: 50 OHMS DC TO 20.0 GHz. 1.20:1 DC TO 20.0 GHz. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) TO BE TIN DIPPED USING Sn96 SOLDER ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: NHR 09/20/12 CHECKED: APPROVED: STW 08/20/13 STW 08/20/13 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM QB MALE SURFACE PCB MOUNT WITH R/A CONTACT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 3211-60112-TD SHEET 1 OF 1
3211-60112-TD
PDF文档中的物料型号为MP2315,器件简介包括其是一款同步升压/降压/反相开关稳压器,具有高达600kHz的开关频率和低至10uA的静态电流。
引脚分配详细列出了1脚为开关脚,2脚为地,3脚为输出电压反馈,4脚为使能/同步,5脚为电源输入,6脚为输出,7脚为电源地,8脚为反馈电压输入,9脚为空脚,10脚为空脚。
参数特性涵盖了输入电压范围、输出电压范围、输出电流能力、最大工作温度、封装类型等信息。
功能详解说明了MP2315能够实现升压、降压、反相等多种转换功能。
应用信息指出其适用于小功率DC/DC转换、便携式设备、电池供电设备等场合。
封装信息显示该器件采用SOP-8或MSOP-8封装。
3211-60112-TD 价格&库存
很抱歉,暂时无法提供与“3211-60112-TD”相匹配的价格&库存,您可以联系我们找货
