3811-40004
3811-40004
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPSPLUGSTR50OHMEDGEMNT
3811-40004 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING B 3X .040 1.02 DCN 41694 DATE APPROVED 09/15 DAL .124 3.15 .094 2.39 2X .011 0.28 MATERIAL: 2X.040 1.02 PRESS SLEVE: BODY & CONTACT: INSULATOR: .090 2.29 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 .009±.001 0.23±0.03 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B 2X.028 0.70 FINISH: A PRESS SLEEVE, BODY & CONTACT: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. INSERT FLUSH TO .002 0.05 ABOVE BODY PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: ENGAGEMENT: DISENGAGEMENT: 50 OHMS DC TO 65.0 GHz 1.25 TO 26.5 GHz 1.35 TO 50.0 GHz .12 X SQRT(F(F IN GHz)) .115 2.92 DETAIL A SCALE 32 : 1 1.5 LBS TYP .50 LBS TYP MATERIAL: FINISH: NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 09/22/09 CHECKED: APPROVED: STW 09/22/09 STW 09/22/09 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS (SB) EDGE LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3811-40004 SHEET 1 OF 1
3811-40004 价格&库存
很抱歉,暂时无法提供与“3811-40004”相匹配的价格&库存,您可以联系我们找货
  • 1+700.515731+90.62241
  • 10+595.4474410+77.03022
  • 25+558.1966225+72.21126
  • 50+531.5798650+68.76797
  • 100+506.23771100+65.48958
库存:578
