SF3211-60024
SF3211-60024
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGSTR50OHMSOLDER
SF3211-60024 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 38042 DATE APPROVED 02/11 STW .380 9.65 .165 4.19 .100 2.54 .112 2.84 .480 12.19 .328 8.33 2X .073 THRU .140 3.56 X 82° MATERIAL: BODY: FERRULE & CONTACT: INSULATOR: .080 2.03 .207 5.26 .083±.001 2.11±0.03 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 RP BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: BODY: FERRULE & CONTACT: PASSIVATED PER AMS-2700, TYPE 2 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27; OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: DWV: OPERATING TEMP.: MATERIAL: 50 OHMS DC TO 40.0 GHz 1.30:1 DC TO 40.0 GHz 325 VRMS -55 C TO +125 C FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FED 02/28/11 CHECKED: APPROVED: STW 02/28/11 STW 02/28/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM SB MALE 2-HOLE FLANGE MOUNT FOR Ø.047 CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 7:1 SF3211-60024 SHEET 1 OF 1
SF3211-60024 价格&库存
很抱歉,暂时无法提供与“SF3211-60024”相匹配的价格&库存,您可以联系我们找货
