FFA.1E.275.CTAC65Z
FFA.1E.275.CTAC65Z
    LEMO(雷莫)
    FFA.1E.275.CTAC65Z
FFA.1E.275.CTAC65Z 数据手册
FFA.1E.275.CTAC65Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1E Termination type Male solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 6.10 - 6.50 mm Status active Matching parts ERA.1E.275.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 23.18 g Performance Configuration 1E.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 10 Amps Specifications Contact Type: Solder Vtest: 2400 V (AC), 3300 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.08 * f/GHz Cable type: RG 179 B/U, RG 187 A/U, RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1E.ZZZ.PA090 Caps: BFA.1E.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1E.275.CTAC65Z 价格&库存
很抱歉,暂时无法提供与“FFA.1E.275.CTAC65Z”相匹配的价格&库存,您可以联系我们找货
