FFA.1E.250.CTAC25Z
FFA.1E.250.CTAC25Z
    LEMO(雷莫)
    FFA.1E.250.CTAC25Z
FFA.1E.250.CTAC25Z 数据手册
FFA.1E.250.CTAC25Z www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 1E Termination type Male solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 2.10 - 2.50 mm Status active Matching parts ERA.1E.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 24.84 g Performance Configuration 1E.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1 mm (0.039in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.23 * f/GHz LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Spanner wrench: DCD.1E.ZZZ.PA090 Caps: BFA.1E.100.NAS Cables CCX.50.RG0.58AU14B FEP White CCX.50.RG1.88AU24B TFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1E.250.CTAC25Z 价格&库存
很抱歉,暂时无法提供与“FFA.1E.250.CTAC25Z”相匹配的价格&库存,您可以联系我们找货
