SF4546-6011
SF4546-6011
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNPTNCJACKSTR50OHMSOLDER
SF4546-6011 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE APPROVED B DCN 41832 11/15 DAL C DCN 42247 04/16 DAL D DCN 48109 11/18 STW 1.200 30.48 MAX .821 20.85 .750 19.05 HEX. .175 4.45 MAX PANEL MATERIAL: BODY, HEX NUT & CLAMP NUT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR PER ASTM A582, TYPE 303 LOCK WASHER: 300 OR 400 SERIES STAINLESS STEEL CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: SILICONE RUBBER FERRULE: BRASS PER ASTM B16 ALLOY UNS C36000 7/16-28 UNEF-2A .375 HEX .625 HEX 1/2-28UNEF-2A .468 MIN 11.89 MIN .500 MIN 12.70 MIN FINISH: BODY, CLAMP NUT, HEX NUT & LOCK WASHER: CONTACT & FERRULE: PASSIVATED PER AMS-2700 RECOMMENDED MOUNTING HOLE GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 18.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: BNK 11/12/15 CHECKED: APPROVED: DAL 11/12/15 DD 03/18/83 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: PTNC JACK, JAM-NUT MOUNT FOR .085 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF4546-6011 SHEET 1 OF 1
SF4546-6011 价格&库存
很抱歉,暂时无法提供与“SF4546-6011”相匹配的价格&库存,您可以联系我们找货
SF4546-6011
  • 25+1203.3065625+155.97144
