FFA.1E.250.CTAC35Z
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
1E
Termination type
Male solder Coaxial
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
3.10 - 3.50 mm
Status
active
Matching parts
ERA.1E.250.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet and nut for fitting a bend relief
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Variant
Z : Nut for fitting a bend relief
Weight
24.33 g
Performance
Configuration
1E.250 : 1 Coax (50 Ohm)
Insulator
T: PTFE
Rated Current
12 Amps
Specifications
Contact Type: Coaxial 50 Ohm (Solder)
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 1 mm (0.039in)
Vtest: 3000 V (AC), 4200 V (DC)
Impedance: 50 Ohm
VSWR: 1.01 + 0.23 * f/GHz
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Cable type: RG 178 B/U, RG 196 A/U, RG 188 A/U, RG 316 B/U, RG 174 A/U, HF-2114, RG 122 /U
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
13
42
28
9
in.
0,51
1,65
1,10
0,35
RECOMMENDED BY LEMO
Tools
2/3
Spanner wrench:
DCD.1E.ZZZ.PA090
Caps:
BFA.1E.100.NAS
Cables
CCX.75.040.195327G
PVC
Grey
3/3
很抱歉,暂时无法提供与“FFA.1E.250.CTAC35Z”相匹配的价格&库存,您可以联系我们找货
