SF4546-6010
SF4546-6010
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNPTNCJACKSTR50OHMSOLDER
SF4546-6010 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING 1.276 MAX 32.41 MAX .750 19.05 HEX. REVISION HISTORY DESCRIPTION REV DATE APPROVED A DCN 39760 04/13 STW B REV. DCN 40887 10/24/14 FED C DCN 41948 12/15 STW .821 20.85 .180 MAX 4.57 MAX PANEL .625 15.88 HEX .375 HEX. 7/16-28 UNEF-2A MATERIAL: BODY, SLEEVE, HEX NUT, CLAMP NUT& FERRULE: .465±.002 ACROSS FLAT NOT ORIENTED TO HEX .4035±.0025 ACROSS FLATS NOT ORIENTED TO HEX STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60 LOCKWASHER: 300 SERIES STAINLESS STEEL 1/2-28 UNEF-2A .500 12.70 FINISH: BODY, SLEEVE, HEX NUT, CLAMP NUT & LOCKWASHER: CONTACT & FERRULE: PASSIVATED PER AMS-2700. GOLD PER ASTM B488, TYPE II, CODE C, CLASS 0.76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00010" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: .475 12.07 RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: 50 OHMS DC TO 15.0 GHz 1.05 + .007(F IN GHz) DC TO 15.0 GHz .04 X SQRT(F(F IN GHz)) SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: GEE 09/26/85 CHECKED: APPROVED: CT 10/85 RD 10/07/85 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: PTNC JACK BULKHEAD MOUNT FOR .141 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 2:1 SF4546-6010 SHEET 1 OF 1
SF4546-6010 价格&库存
很抱歉,暂时无法提供与“SF4546-6010”相匹配的价格&库存,您可以联系我们找货
SF4546-6010
  • 1+1534.789101+198.80890
  • 10+1202.2558010+155.73420
  • 25+1202.1600025+155.72180
  • 50+1185.4028050+153.55120
库存:3
SF4546-6010
  • 25+1426.7061025+184.80834
