FFA.2S.250.CTAC62
FFA.2S.250.CTAC62
    LEMO(雷莫)
    FFA.2S.250.CTAC62
FFA.2S.250.CTAC62 数据手册
FFA.2S.250.CTAC62 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 2S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 5.30 - 6.20 mm Status active Matching parts ERA.2S.250.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 33.90 g Performance Configuration 2S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 2 mm (0.079in) Bucket Dia.: 1.8 mm (0.071in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 0.95 * f/GHz Cable type: RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 14.8 52 40 11 in. 0,58 2,05 1,57 0,43 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2S.ZZZ.PA110 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 159580 PVC Black 62000 PVC Black CCX.50.080.297538N PVC Black CCX.50.RG0.58AU61J PVC Yellow CCX.75.RG0.59BU62N PVC Black CCX.93.RG0.62AU62N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.2S.250.CTAC62 价格&库存
很抱歉,暂时无法提供与“FFA.2S.250.CTAC62”相匹配的价格&库存,您可以联系我们找货
