FAA.2S.650.CTA
FAA.2S.650.CTA
    LEMO(雷莫)
    FAA.2S.650.CTA
FAA.2S.650.CTA 数据手册
FAA.2S.650.CTA www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2S Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts PCA.2S.650.CTLC52 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FAA*: Fixed plug, non-latching, nut fixing Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 18.12 g Performance Configuration 2S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 1.6 mm (0.063in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.3 * f/GHz Cable type: RGT 174,Belden 9222,8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A A B E L M S1 S3 e mm. 18 18 19.5 4 25 13.8 13.5 17 M15x1.0 in. 0,71 0,71 0,77 0,16 0,98 0,54 0,53 0,67 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FAA.2S.650.CTA 价格&库存
很抱歉,暂时无法提供与“FAA.2S.650.CTA”相匹配的价格&库存,您可以联系我们找货
