ERA.3S.250.CTL
ERA.3S.250.CTL
    LEMO(雷莫)
    ERA.3S.250.CTL
ERA.3S.250.CTL 数据手册
ERA.3S.250.CTL www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3S Termination type Female solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.3S.250.CLAC72 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 24.06 g Performance Configuration 3S.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 26 Amps Specifications Contact Type: Coaxial 50 Ohm (Solder) Contact Dia.: 3 mm (0.118in) Bucket Dia.: 2.7 mm (0.106in) Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.06 + 0.5 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/4 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 22 25.1 11.5 29 2 16.5 22 M18x1.0 in. 0,87 0,99 0,45 1,14 0,08 0,65 0,87 RECOMMENDED BY LEMO Tools Spanner wrench: Socket for torque wrench DCM.65.200.AZ LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/4 Cables 158480 PUR Black 158490 PVC Black 159580 PVC Black 17420 PVC Black 17450 COPOLYMER Black 178190 PTFE Brown 18000 PTFE Brown 18700 PTFE White 18800 PTFE White 196270 PTFE White 213000 PE Black 311100 PVC Black 31600 PTFE Brown 62000 PVC Black CCX.50.030.083.180B White CCX.50.080.297538N PVC Black CCX.50.088.292495N PVC Black CCX.50.RG0.58AU14B FEP White CCX.50.RG0.58AU61J PVC Yellow CCX.50.RG1.74-U25N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74AU28N PVC Black CCX.50.RG1.74U25N PVC Black CCX.50.RG1.78BU18M FEP Brown CCX.50.RG1.78BU18M PTFE Brown CCX.50.RG1.88AU24B TFE White CCX.50.RG1.88AU26B PFA White CCX.50.RG1.88AU26B PTFE White CCX.50.RG1.96AU19B PTFE White CCX.50.RG1.96AU20B PFA White CCX.50.RG2.13U10N PE Black CCX.50.RG3.16BU26M FEP Brown CCX.50.RG3.16U28M PTFE Brown CCX.50.RG5.8CU50N PVC Black CCX.75.040.195327G PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/4 CCX.75.RG0.11AU10N CCX.75.RG0.59BU62N PVC PVC Black Black CCX.75.RG1.79BU26M FEP Brown CCX.75.RG1.87AU26B PFA White CCX.75.RG1.87AU27B PTFE White CCX.93.RG0.62AU62N PVC Black CCX.95.RG1.80BU36M PTFE Brown CCX.95.RG1.95AU37B PFA White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 4/4
ERA.3S.250.CTL 价格&库存
很抱歉,暂时无法提供与“ERA.3S.250.CTL”相匹配的价格&库存,您可以联系我们找货
