3212-40003-TD
3212-40003-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMPLUGR/A50OHMPCB
3212-40003-TD 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - DCN 43145 DATE APPROVED 02/17 GPF .135 3.43 RP 4X .088 2.24 .289 7.34 4X .020±.002 0.51±0.05 .132 3.35 .024±.001 0.61±0.03 4X .096 2.44 SOLDER .145 3.68 2X .100±.002 2.54±0.05 .145 3.68 .256 6.50 MATERIAL: BODY, CONTACT & SLEEVE: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 SHROUD: STAINLESS STEEL PER AMS 5640, ALLOY UNS S30300, TYPE 1 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B NOTES: 1. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) 2. TO BE TIN DIPPED USING Sn96 SOLDER 3. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING FINISH: BODY, SLEEVE & CONTACT: SHROUD: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PASSIVATED PER AMS-2700, TYPE 2 FINISH: PERFORMANCE: IMPEDANCE: MATERIAL: 50 OHMS SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VB 02/24/17 CHECKED: APPROVED: GPF 02/24/17 GPF 02/24/17 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM R/A MALE SMOOTH BORE TO PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 8:1 3212-40003-TD SHEET 1 OF 1
3212-40003-TD 价格&库存
很抱歉,暂时无法提供与“3212-40003-TD”相匹配的价格&库存,您可以联系我们找货
