ERN.00.650.GLL
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
00
Termination type
Female solder
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFC.00.650.GLAC22Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERN*: Fixed receptacle, nut fixing, with earthing tags
Keying
Circular, female
Housing Material
PEEK (Polyetheretherketone) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass
latch sleeve and mid pieces
Weight
1.39 g
Performance
Configuration
00.650 : 1 Triax (50 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
3 Amps
Specifications
Contact Type: Triaxial 50 Ohm (Solder)
Contact Dia.: 0.5 mm (0.02"in)
Vtest: 1200 V (AC), 1700 V (DC)
Impedance: 50 Ohm
VSWR: 1.1 + 0.11 * f/GHz
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Endurance (Shell): 5000 mating cycles
DRAWINGS
Dimensions
A
L
mm.
8
15
in.
0,31
0,59
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“ERN.00.650.GLL”相匹配的价格&库存,您可以联系我们找货
