ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
DCN 42213
DATE
APPROVED
3/16
STW
.500 12.70
.320 8.13
.180 4.57
.075 1.91
.120 3.05
.068 1.73
.295 7.49
.215 5.46
.012 0.30
.095 2.40
1/4-36 UNS-2A
MATERIAL:
BODY &
INSERT:
.060 1.52
STAINLESS STEEL PER AMS-5640,
ALLOY UNS S30300, TYPE 1
CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
DIELECTRIC BEAD:
ULTEM 1000
.070 1.77
.074 1.88
.210 5.33
SOLDER
NOTES:
1.
2.
FINISH:
BODY,
INSERT &
CONTACT:
GOLD PER ASTM B 488, TYPE II,
CODE C, CLASS 0.76, OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00010" MIN.
PERFORMANCE:
FREQ.RANGE:
VSWR:
MATERIAL:
FINISH:
SEE NOTES
SEE NOTES
SURFACE AREA:
DC TO 40.0 GHz
1.25:1 MAX. DC TO 40.0 GHz.
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
TO BE TIN DIPPED USING Sn96 SOLDER.
ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING.
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
GPF 3/28/16
CHECKED:
APPROVED:
STW 3/28/16
STW 3/28/16
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SVK JACK PCB MOUNT
Ø.012 PIN FOR .062" PCB
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 4:1
1521-60051-TD
SHEET 1 OF 1
很抱歉,暂时无法提供与“1521-60051-TD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1395.811011+180.66787
- 10+1186.5232210+153.57854
- 25+1112.3226825+143.97434
- 50+1059.3024050+137.11162
- 国内价格 香港价格
- 1+795.383511+101.97059
- 10+689.3312610+88.37437
- 25+608.2379225+77.97796
