FFA.2S.275.CLAC52
FFA.2S.275.CLAC52
    LEMO(雷莫)
    FFA.2S.275.CLAC52
FFA.2S.275.CLAC52 数据手册
FFA.2S.275.CLAC52 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 2S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 4.30 - 5.20 mm Status active Matching parts ERA.2S.275.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 32.90 g Performance Configuration 2S.275 : 1 Coax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Coaxial 75 Ohm (Solder) Contact Dia.: 1.6 mm (0.063in) Bucket Dia.: 1.4 mm (0.055in) Vtest: 1500 V (AC), 2100 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.03 * f/GHz Cable type: RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 14.8 52 40 11 in. 0,58 2,05 1,57 0,43 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2S.ZZZ.PA110 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 158480 PUR Black 158490 PVC Black CCX.50.088.292495N PVC Black CCX.50.RG5.8CU50N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.2S.275.CLAC52 价格&库存
很抱歉,暂时无法提供与“FFA.2S.275.CLAC52”相匹配的价格&库存,您可以联系我们找货
