FFA.2S.275.CLLC52
www.lemo.com
SUMMARY
# Wires
Coax
1
Image is for illustrative purpose only
Series
2S
Termination type
Female solder Coaxial
IP rating
50
AWG wire size
0.00 - 0.00
Cable Ø
4.30 - 5.20 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, female
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
34.56 g
Performance
Configuration
2S.275 : 1 Coax (75 Ohm)
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
12 Amps
Specifications
Contact Type: Coaxial 75 Ohm (Solder)
Contact Dia.: 1.6 mm (0.063in)
Bucket Dia.: 1.4 mm (0.055in)
Vtest: 1500 V (AC), 2100 V (DC)
Impedance: 75 Ohm
VSWR: 1.02 + 0.03 * f/GHz
Cable type: RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 144 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
14.8
52
40
11
in.
0,58
2,05
1,57
0,43
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.2S.ZZZ.PA110
2/3
Cables
158480
PUR
Black
158490
PVC
Black
CCX.50.088.292495N
PVC
Black
CCX.50.RG5.8CU50N
PVC
Black
3/3
很抱歉,暂时无法提供与“FFA.2S.275.CLLC52”相匹配的价格&库存,您可以联系我们找货
