SF1732-6004
SF1732-6004
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMAJACKSTR50OHMSOLDER
SF1732-6004 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING DATE APPROVED B DCN 41831 10/15 STW C REV. DCN 47879 08/28/18 STW .710 18.03 .380 9.65 .065 1.65 .060 1.52 MIN. AXIAL FLOAT .750 19.05 2X .372 9.45 .560 14.22 .020 0.51 MIN. RADIAL FLOAT 2X MATERIAL: INSERT, OUTER BODY & INNER BODY: .180 4.57 .125 3.18 MAX PANEL .102 2.59 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR ASTM A582, TYPE 303, CONDITIION A. LOCK RING: STAINLESS STEEL PER TYPE PH15-7 OR 17-7. COMPR. SPRING: STAINLESS STEEL PER ASTM A313, TYPE 302, ALLOY No. UNS S30200. CONTACTS, SLEEVE & SHIM SPRING: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B. .560±.004 14.22±0.10 +.001 +0.03 .378 - .002 9.60 - 0.05 .280 7.11 FINISH: INSERT, LOCK RING, OUTER BODY & COMPR SPRING: SLEEVE, CONTACTS, INNER BODY & SHIM SPRING: 2X 2-56 UNC-2B PASSIVATED PER AMS 2700 RECOMMENDED MOUNTING HOLE GOLD PER ASTM B488, TYPE II, CODE C, CLASS .076 OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 22.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VMJ 01/06/00 CHECKED: APPROVED: STW 01/06/00 STW 01/06/00 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA JACK FLANGE MOUNT FOR .141 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF1732-6004 SHEET 1 OF 1
SF1732-6004 价格&库存
很抱歉,暂时无法提供与“SF1732-6004”相匹配的价格&库存,您可以联系我们找货
