SF1733-6006
SF1733-6006
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMAJACKSTR50OHMSOLDER
SF1733-6006 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING UPDATE E-RING MATERIAL TO MATCH CURRENT DRAWING: 040-11-002. -TMW 5/12/17 REVISION HISTORY DESCRIPTION REV A DCN 41831 .380 9.65 .065 1.65 .020 0.51 MIN. RADIAL FLOAT .750 19.05 2X COIL SPRING: 300 SERIES STAINLESS STEEL. .060 1.52 MIN. AXIAL FLOAT 2X .125 3.18 MAX. PANEL .102 2.59 BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B +0.03 +.001 .378 - .002 9.60 - 0.05 .560±.004 14.22±0.10 FINISH: INSERT, LOCK RING, OUTER BODY & COIL SPRING: SLEEVE, CONTACTS, INNER BODY & SHIM SPRING: .280 7.11 PASSIVATED PER AMS-2700 GOLD PER ASTM B488, TYPE II, CODE C, CLASS .076, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: FREQ. RANGE: .372 9.45 .560 14.22 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 STAINLESS STEEL PER ASTM-A-240. ALLOY UNS S30400, TYPE 304. INSULATOR: STW .120 3.05 LOCK RING: CONTACTS, SLEEVE & SHIM SPRING: APPROVED .710 18.03 MATERIAL: INSERT, OUTER BODY & INNER BODY: DATE 10/15 2X 2-56 UNC-2B RECOMMENDED MOUNTING HOLE MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 22.0 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 .030 .010 .005 ANGULAR: X X X' 1 0' 15' INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: VMJ 01/04/00 CHECKED: APPROVED: STW 01/04/00 STW 01/04/00 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA JACK FLANGE MOUNT FOR .085 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 SF1733-6006 SHEET 1 OF 1
SF1733-6006 价格&库存
很抱歉,暂时无法提供与“SF1733-6006”相匹配的价格&库存,您可以联系我们找货
