3221-60003
3221-60003
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPMJACKSTR50OHMSOLDER
3221-60003 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING .220 5.59 DATE APPROVED B DCN 39878 06/13 STW C DCN 40210 12/13 STW .470 11.93 MATERIAL: BODY & CONTACT: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 FERRULE: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATOR: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B SPRING: STAINLESS STEEL PER ASTM A313 QUARTER BACK NUT: PASSIVATED PER AMS-2700. FINISH: BODY, FERRULE & CONTACT: QUARTER BACK NUT & SPRING: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. MATERIAL: PASSIVATED PER AMS 2700 FINISH: SEE NOTES SEE NOTES SURFACE AREA: PERFORMANCE: N/A PROPRIETARY IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 65.0 GHz THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: CHECKED: APPROVED: NHR 09/20/12 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPM JACK W/ QUARTER BACK NUT FOR Ø.047 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 10:1 3221-60003 SHEET 1 OF 1
3221-60003 价格&库存
很抱歉,暂时无法提供与“3221-60003”相匹配的价格&库存,您可以联系我们找货
  • 1+1369.659981+177.28299
  • 10+1164.3278610+150.70567
  • 25+1091.5074025+141.28010
  • 50+1039.4798650+134.54587
库存:25
