FFA.2S.650.CTAC72
FFA.2S.650.CTAC72
    LEMO(雷莫)
    FFA.2S.650.CTAC72
FFA.2S.650.CTAC72 数据手册
FFA.2S.650.CTAC72 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2S Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 6.30 - 7.20 mm Status active Matching parts ERA.2S.650.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 34.25 g Performance Configuration 2S.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 12 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 1.6 mm (0.063in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.3 * f/GHz Cable type: RGT 174,Belden 9222,8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 14.8 52 40 11 in. 0,58 2,05 1,57 0,43 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2S.ZZZ.PA110 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.2S.650.CTAC72 价格&库存
很抱歉,暂时无法提供与“FFA.2S.650.CTAC72”相匹配的价格&库存,您可以联系我们找货
