ROHS COMPLIANT
PRODUCT DATA DRAWING
REVISION HISTORY
DESCRIPTION
REV
DATE
APPROVED
C
REV. DCN 43069
02/03/17
STW
D
DCN 46900
10/17
STW
.480 12.19
.192 4.88
.288 7.32
.160±.002 4.06±0.05
PANEL
.188 4.78
.1475±.0005 3.75±0.01
.1655±.0025 4.20±0.06
.160±.002 4.06±0.05
MATERIAL:
BODY, LOCK RING &
CONTACT:
BERYLLIUM COPPER PER ASTM B196,
ALLOY No. UNS C17300, TD04
FERRULE:
BRASS PER ASTM B16, ALLOY UNS No. C36000
INSULATORS:
PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B
NOTES:
1.
FINISH:
BODY, CONTACT,
LOCK RING &
FERRULE:
GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27,
OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN.
PERFORMANCE:
IMPEDANCE:
FREQ. RANGE:
DWV:
OPERATING TEMP.:
.150±.001 3.81±0.03
RECOMMENDED MTG HOLE
MATERIAL:
FINISH:
50 OHMS
DC TO 65.0 GHz
325 VRMS
-55 C TO +125 C
USE 500-32-014 FOR EXTRACTION.
SEE NOTES
SEE NOTES
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS]
2) ALL DIMENSIONS ARE AFTER PLATING.
3) BREAK CORNERS & EDGES .005 R. MAX.
4) CHAM. 1ST & LAST THREADS.
5) SURFACE ROUGHNESS 63 e MIL-STD-10.
6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
7) REMOVE ALL BURRS
DRAWN:
DAL 05/05/09
CHECKED:
APPROVED:
PJS 05/05/09
PJS 05/05/09
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
SMPM FEMALE FOR
T-FLEX 405 CABLE
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 13:1
3221-40010
SHEET 1 OF 1
很抱歉,暂时无法提供与“3221-40010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1597.185091+204.63740
- 10+1384.2316610+177.35300
