3811-40003-TD
3811-40003-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPSPLUGSTR50OHMEDGEMNT
3811-40003-TD 数据手册
ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV PRODUCT DATA DRAWING - 3X .040 1.02 DCN 42490 DATE APPROVED 07/16 DAL .124 3.15 .094 2.39 2X .011 0.28 NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com 2. TO BE TIN DIPPED USING Sn96 SOLDER 3. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING 2X.040 1.02 .090 2.29 .009±.001 0.23±0.03 MATERIAL: PRESS SLEVE: BODY & CONTACT: INSULATOR: 2X.028 0.70 STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 NOTE 2 A BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B FINISH: PRESS SLEEVE, BODY & CONTACT: INSERT FLUSH TO .002 0.05 ABOVE BODY NOTE 2 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. .115 2.92 DETAIL A SCALE 32 : 1 PERFORMANCE: IMPEDANCE: FREQ. RANGE: VSWR: INSERTION LOSS: ENGAGEMENT: DISENGAGEMENT: 50 OHMS DC TO 65.0 GHz 1.25 TO 26.5 GHz 1.35 TO 50.0 GHz .12 X SQRT(F(F IN GHz)) 2.5 LBS TYP 4.5 LBS TYP MATERIAL: FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: JMC 09/22/09 CHECKED: APPROVED: STW 09/22/09 STW 09/22/09 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS (FD) EDGE LAUNCH SIZE CAGE CODE DWG. NO. B 95077 SCALE: 16:1 3811-40003-TD SHEET 1 OF 1
3811-40003-TD
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
3811-40003-TD 价格&库存
很抱歉,暂时无法提供与“3811-40003-TD”相匹配的价格&库存,您可以联系我们找货
3811-40003-TD
  • 1+1600.292221+207.02223
  • 5+1107.295035+143.24552
  • 7+1086.361637+140.53746
  • 13+1066.1984913+137.92905
  • 19+1063.4835019+137.57783
库存:89
