REVISION HISTORY
DESCRIPTION
DATE
APPROVED
C
DCN 32895
03/05
BRT
D
DCN 42213
4/16
DAL
REV
PRODUCT DATA DRAWING
.711 18.05
.238 6.033
MATERIAL:
BODY &
INSERT:
CONTACT,
SPRING CLIP,
CONTACT SLEEVE:
SHIM SPRING,
OUTER CONTACT:
.120 3.048
.300 MAX 7.620 MAX
STAINLESS STEEL PER AMS-5640,
UNS S30300, TYPE 303
BERYLLIUM COPPER PER ASTM B196
ALLOY UNS C17300, COND TD04
.568 MIN 14.43 MIN
WITH .060 MIN.
AXIAL FLOAT
BERYLLIUM COPPER PER ASTM B194
ALLOY UNS C17200, COND TD04
COIL SPRING:
MUSIC WIRE PER ASTM A228
E-RING:
STAINLESS STEEL PER ASTM A240
ALLOY UNS S30400, TYPE 304
INSULATOR:
PTFE PER ASTM D1710, TYPE I, GRADE 1,
CLASS B
NOTE 1
.0475±.0025 1.207±0.064
PANEL THICKNESS
.500 12.70
.0475±.0025 1.21±0.06
FINISH:
BODY,
INSERT,
SPRING CLIP,
CONTACTS,
SHIM SPRING:
.2815±.0015 7.15±0.04
GOLD PER ASTM B488, TYPE II,
CODE C, CLASS 1.27; OVER NICKEL
PER AMS-QQ-N-290, CLASS 1, .00005 MIN.
COIL SPRING:
ZINC PER ASTM B633
E-RING:
PASSIVATED PER AMS-QQ-P-35, TYPE II
MOUNTING HOLE
NOTES:
1. ACCEPTS .085 SEMI-RIGID CABLE OR T-FLEX 405 CABLE.
MATERIAL:
PERFORMANCE:
SEE ABOVE
DIMENSIONS ARE IN INCHES TOLERANCES:
FRACTIONAL:
FINISH:
IMPEDANCE:
FREQ. RANGE:
.257±.001 6.53±0.03
50 OHMS
DC TO 28.0 GHz
SEE ABOVE
SURFACE AREA:
N/A
PROPRIETARY
THE INFORMATION CONTAINED IN THIS DRAWING
IS THE SOLE PROPERTY OF SV MICROWAVE, INC.
ANY REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
SV MICROWAVE, INC IS PROHIBITED.
DECIMAL: .X
.XX
.XXX
1/64
ANGULAR: X
X X'
1 0'
15'
.030
.010
.005
INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M - 1994
THIRD ANGLE PROJECTION
SV Microwave, Inc.
UNLESS OTHERWISE SPECIFIED
1) ALL DIMENSIONS ARE AFTER PLATING.
2) BREAK CORNERS & EDGES .005 R. MAX.
3) CHAM. 1ST & LAST THREADS.
4) SURFACE ROUGHNESS 63 S MIL-STD-10.
5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC
WITHIN .005 T.I.R.
6) REMOVE ALL BURRS
DRAWN:
VMJ 02/12/99
CHECKED:
APPROVED:
JM 02/14/99
JM 02/14/99
2400 Centrepark West Drive, Suite 100
West Palm Beach, FL 33409
TITLE:
BMMA JACK
FLOAT MOUNT
SIZE CAGE CODE DWG. NO.
B
95077
SCALE: 4:1
1440-6001
SHEET 1 OF 1
很抱歉,暂时无法提供与“1440-6001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1377.382401+178.39553
- 10+1170.9067210+151.65326
- 25+1097.6713025+142.16797
- 50+1045.3545950+135.39202
