FFA.1E.650.CTAC35Z
FFA.1E.650.CTAC35Z
    LEMO(雷莫)
    FFA.1E.650.CTAC35Z
FFA.1E.650.CTAC35Z 数据手册
FFA.1E.650.CTAC35Z www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 1E Termination type Male solder IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 3.10 - 3.50 mm Status active Matching parts ERA.1E.650.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet and nut for fitting a bend relief Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Variant Z : Nut for fitting a bend relief Weight 23.99 g Performance Configuration 1E.650 : 1 Triax (50 Ohm) Insulator T: PTFE Rated Current 6 Amps Specifications Contact Type: Solder Vtest: 1200 V (AC), 1690 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.17 * f/GHz Cable type: RGT 178, RGT 174,Belden 9222 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S2 mm. 13 42 28 9 in. 0,51 1,65 1,10 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1E.ZZZ.PA090 Caps: BFA.1E.100.NAS LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1E.650.CTAC35Z 价格&库存
很抱歉,暂时无法提供与“FFA.1E.650.CTAC35Z”相匹配的价格&库存,您可以联系我们找货
