1789-6001-TD
1789-6001-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNBMARCPTR/A50OHMPCB
1789-6001-TD 数据手册
CONFIGURATION CONTROL LEVEL: 3 ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV - DCN 43089 DATE APPROVED 02/17 MAL .240 6.10 .525±.010 13.34±0.25 .250±.002 6.35±0.05 2X .200 5.08 .0505±.0005 1.28±0.01 .578±.006 14.68±0.15 4X .040 1.02 .155 3.94 .458 11.63 MATERIAL: BODIES: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 TERMINAL: BRASS PER ASTM B16, ALLOY UNS No. C36000 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B O-RING: FLUOROCARBON RUBBER PER AMS 7276 PRESS CAP: STAINLESS STEEL PER ASTM-A-240, ALLOY UNS S30400, TYPE 304 NOTES: 1. FOR RECOMMENDED FOOTPRINT TO YOUR SPECIFIC PCB, CONTACT SV MICROWAVE SALES DEPARTMENT (sales@svmicro.com, 561-840-1800) 2. TO BE TIN DIPPED USING Sn96 SOLDER 3. ALL DIMENSIONS APPLY PRIOR TO SOLDER DIPPING FINISH: BODIES, CONTACTS & TERMINAL: PRESS CAP: GOLD PER ASTM B488, TYPE II, CODE C, CLASS .76, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. GOLD PER ASTM B 488, TYPE I, CODE C, CLASS .50, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. PERFORMANCE: IMPEDANCE: 50 OHMS MATERIAL: FINISH: PER BOM PER BOM PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE AFTER PLATING. 2) BREAK CORNERS & EDGES .005 R. MAX. 3) CHAM. 1ST & LAST THREADS. 4) SURFACE ROUGHNESS 63 MIL-STD-10. 5) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 6) REMOVE ALL BURRS DRAWN: VB 02/10/17 CHECKED: APPROVED: MAL 02/10/17 MAL 02/10/17 E.M. SIMULATION: N/A 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: BMA R/A PLUG RECEPTACLE PCB MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 4:1 1789-6001-TD SHEET 1 OF 1
1789-6001-TD 价格&库存
很抱歉,暂时无法提供与“1789-6001-TD”相匹配的价格&库存,您可以联系我们找货
