SF1511-60044
SF1511-60044
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONN2.92MMPLGSTR50OHMSOLDER
SF1511-60044 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING 3X .312 7.92 HEX REVISION HISTORY DESCRIPTION REV DATE 01 PRELIMINARY 09/12 - REL. NRN 42505 08/01/18 APPROVED STW .612 15.54 MATERIAL: BODY, SLEEVE, FERRULE CLAMP NUT, & COUPLING NUT: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 OR ASTM A582, TYPE 303, CONDITION A. CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04. LOCK RING: BERYLLIUM COPPER PER ASTM B194, B196 OR B197 ALLOY No. UNS C17200 OR C17300. BEAD: PEI (ULTEM1000) PER ASTM D 5205. GASKET: SILICONE RUBBER PER A-A-59588, CLASS 2B, GRADE 50/60. FINISH: BODY, SLEEVE, CLAMP NUT & COUPLING NUT: FERRULE & CONTACT: PASSIVATED PER AMS 2700 GOLD PER ASTM B488, TYPE I, CODE C, CLASS 1.27 OVER NICKEL PER AMS-C-26074, CLASS 3, .00005" MIN. MATERIAL: FINISH: PERFORMANCE: IMPEDANCE: FREQ. RANGE: SEE NOTES SEE NOTES SURFACE AREA: 50 OHMS DC TO 34.0 GHz N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: NHR 09/28/12 CHECKED: APPROVED: JMC 07/31/18 STW 07/31/18 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: 2.92mm PLUG FOR UT-141 S.R. CABLE SIZE CAGE CODE DWG. NO. B 95077 SCALE: 6:1 SF1511-60044 SHEET 1 OF 1
SF1511-60044 价格&库存
很抱歉,暂时无法提供与“SF1511-60044”相匹配的价格&库存,您可以联系我们找货
