PSA.2E.250.CTLC55
PSA.2E.250.CTLC55
    LEMO(雷莫)
    PSA.2E.250.CTLC55
PSA.2E.250.CTLC55 数据手册
PSA.2E.250.CTLC55 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 2E Termination type Female solder Coaxial IP rating 68 when mated AWG wire size 0.00 - 0.00 Cable Ø 5.10 - 5.50 mm Status active Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 62.86 g Performance Configuration 2E.250 : 1 Coax (50 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Contact Type: Solder Vtest: 3000 V (AC), 4200 V (DC) Impedance: 50 Ohm VSWR: 1.02 + 0.95 * f/GHz Cable type: RG 58 C/U, RG 302 /U, RG 400 /U, 2YCCY, RG 59 B/U, RG 223 /U, HF-5408 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S2 S3 e mm. 25 27.5 9 54 5 18.5 12 24 M20x1.0 in. 0,98 1,08 0,35 2,13 0,20 0,73 0,47 0,94 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2E.ZZZ.PA120 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.2E.250.CTLC55 价格&库存
很抱歉,暂时无法提供与“PSA.2E.250.CTLC55”相匹配的价格&库存,您可以联系我们找货
