FFA.3S.275.CTAC72
FFA.3S.275.CTAC72
    LEMO(雷莫)
    FFA.3S.275.CTAC72
FFA.3S.275.CTAC72 数据手册
FFA.3S.275.CTAC72 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 5.80 - 7.20 mm Status active Matching parts ERA.3S.275.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 55.13 g Performance Configuration 3S.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Contact Type: Coaxial 75 Ohm (Solder) Contact Dia.: 2 mm (0.0787in) Bucket Dia.: 1.8 mm (0.0708in) Vtest: 2700 V (AC), 3900 V (DC) Impedance: 75 Ohm VSWR: 1.04 + 0.05 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 17.8 61 46 14 in. 0,70 2,40 1,81 0,55 RECOMMENDED BY LEMO Tools Spanner wrench: DCP.91.023.TN LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 159580 PVC Black 62000 PVC Black CCX.50.RG0.58AU61J PVC Yellow CCX.75.RG0.59BU62N PVC Black CCX.93.RG0.62AU62N PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.3S.275.CTAC72 价格&库存
很抱歉,暂时无法提供与“FFA.3S.275.CTAC72”相匹配的价格&库存,您可以联系我们找货
