FFA.3S.275.CTAC10
FFA.3S.275.CTAC10
    LEMO(雷莫)
    FFA.3S.275.CTAC10
FFA.3S.275.CTAC10 数据手册
FFA.3S.275.CTAC10 www.lemo.com SUMMARY # Wires Coax 1 Image is for illustrative purpose only Series 3S Termination type Male solder Coaxial IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 0.00 - 0.00 mm Status obsolete Alternative part FFA.3S.275.CTAC11 Matching parts ERA.3S.275.CTL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 56.51 g Performance Configuration 3S.275 : 1 Coax (75 Ohm) Insulator T: PTFE Rated Current 15 Amps Specifications Contact Type: Coaxial 75 Ohm (Solder) Contact Dia.: 2 mm (0.0787in) Bucket Dia.: 1.8 mm (0.0708in) Vtest: 2700 V (AC), 3900 V (DC) Impedance: 75 Ohm VSWR: 1.04 + 0.05 * f/GHz Cable type: RG 213/U, RG 115 A/U, RG 11 A/U, RG 144/U, RG 165 /U LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 17.8 61 46 14 in. 0,70 2,40 1,81 0,55 RECOMMENDED BY LEMO Tools Spanner wrench: DCP.91.023.TN LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.3S.275.CTAC10 价格&库存
很抱歉,暂时无法提供与“FFA.3S.275.CTAC10”相匹配的价格&库存,您可以联系我们找货
