FFA.1E.650.CTAC60
www.lemo.com
SUMMARY
# Wires
Triax
1
Image is for illustrative purpose only
Series
1E
Termination type
Male solder
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
5.60 - 6.00 mm
Status
active
Matching parts
ERA.1E.650.CTL
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
FFA*: Straight plug, cable collet
Keying
Circular, male
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
22.56 g
Performance
Configuration
1E.650 : 1 Triax (50 Ohm)
Insulator
T: PTFE
Rated Current
6 Amps
Specifications
Contact Type: Solder
Vtest: 1200 V (AC), 1690 V (DC)
Impedance: 50 Ohm
VSWR: 1.01 + 0.17 * f/GHz
Cable type: RGT 178, RGT 174,Belden 9222
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +200°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
L
M
S2
mm.
13
42
28
9
in.
0,51
1,65
1,10
0,35
RECOMMENDED BY LEMO
Tools
Spanner wrench:
DCD.1E.ZZZ.PA090
Caps:
BFA.1E.100.NAS
2/3
3/3
很抱歉,暂时无法提供与“FFA.1E.650.CTAC60”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+474.3459910+61.36390
