FFP.2S.650.CLAC72
FFP.2S.650.CLAC72
    LEMO(雷莫)
    CONN INLINE PLUG TRIAX PIN SLDER
FFP.2S.650.CLAC72 数据手册
FFP.2S.650.CLAC72 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2S Termination type Male solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 6.30 - 7.20 mm Status active Matching parts ERA.2S.650.CLL Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFP*: Straight plug, cable collet and inner anti-rotating device Keying Circular, male Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 33.43 g Performance Configuration 2S.650 : 1 Triax (50 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Triaxial 50 Ohm (Solder) Contact Dia.: 1.6 mm (0.063in) Vtest: 1200 V (AC), 1700 V (DC) Impedance: 50 Ohm VSWR: 1.01 + 0.3 * f/GHz Cable type: RGT 174,Belden 9222,8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 14.8 52 40 11 in. 0,58 2,05 1,57 0,43 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2S.ZZZ.PA110 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFP.2S.650.CLAC72
物料型号:FFP.2S.650.CLAC72
器件简介:LEMO公司生产的三同轴电缆连接器
引脚分配:1个Triax接口
参数特性: - 系列:2S - 连接器类型:直插头,带电缆固定装置和内部防旋转装置 - 键槽:圆形,雄性 - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和固定螺母,镍(SAE AMS QQ N 290])镀层的锁紧套和中间件 - 重量:33.43克
功能详解: - 配置:2S.650:1个三同轴(50欧姆) - 绝缘体:PEEK(UL 94 / V-0/1.5) - 额定电流:12安培 - 接触类型:三同轴50欧姆(焊接) - 接触直径:1.6毫米(0.063英寸) - 电压测试:1200伏交流电,1700伏直流电 - 阻抗:50欧姆 - VSWR:1.01 + 0.3 f/GHz - 电缆类型:RGT 174, Belden 9222, 8215, 8232A, HF-2426, Triax 8 Nokia, 375 029 LEDE
应用信息: - 耐久性(外壳):5000次配对周期 - 温度范围:-55°C至+250°C - 湿度:在60°C/140°F时≤95% - 振动:15 g(10 Hz - 2000 Hz) - 冲击抵抗力:100 g(6 ms) - 气候类别:50/175/21 - 屏蔽:最小75 dB(10 MHz),最小40 dB(1 GHz) - 盐雾腐蚀:>144小时
封装信息: - 推荐工具:DCD.2S.ZZZ.PA110扳手
FFP.2S.650.CLAC72 价格&库存
很抱歉,暂时无法提供与“FFP.2S.650.CLAC72”相匹配的价格&库存,您可以联系我们找货
