PSA.2S.675.CLLC32
PSA.2S.675.CLLC32
    LEMO(雷莫)
    CONN PNL RCPT TRIAX SKT SLDER
PSA.2S.675.CLLC32 数据手册
PSA.2S.675.CLLC32 www.lemo.com SUMMARY # Wires Triax 1 Image is for illustrative purpose only Series 2S Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 2.50 - 3.20 mm Status active Matching parts FFA.2S.675.CLAC32 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model PSA*: Fixed receptacle, nut fixing, cable collet Keying Circular, female Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 32.32 g Performance Configuration 2S.675 : 1 Triax (75 Ohm) Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6 Amps Specifications Contact Type: Solder Vtest: 1200 V (AC), 1700 V (DC) Impedance: 75 Ohm VSWR: 1.02 + 0.07 * f/GHz Cable type: Belden 8215,8232A,HF-2426,Triax 8 Nokia,375 029 LEDE, RGT 179 Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A B C E L M S1 S2 S3 e mm. 18 19.5 8.5 8.5 50 1.8 13.5 11 17 M15x1.0 in. 0,71 0,77 0,33 0,33 1,97 0,07 0,53 0,43 0,67 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2S.ZZZ.PA110 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
PSA.2S.675.CLLC32 价格&库存
很抱歉,暂时无法提供与“PSA.2S.675.CLLC32”相匹配的价格&库存,您可以联系我们找货
