3811-60005-TD
3811-60005-TD
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPSPLUGSTR50OHMSMD
3811-60005-TD 数据手册
PRODUCT DATA DRAWING ROHS COMPLIANT REVISION HISTORY DESCRIPTION REV DATE APPROVED - DCN 42353 05/16 DAL A DCN 42425 06/16 STW .090 2.29 .030 0.76 SOLDER .008 0.20 4X .025 0.64 SLOTS .095 2.41 .009 0.23 .065 1.65 RP .041 1.04 .110 2.79 MATERIAL: 4X .025 0.64 BODY: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 PIN: KOVAR PER ASTM-F15 GLASS: CORNING 7070 OR EQUIVALENT .010 0.25 .065 1.65 RECOMMENDED PCB LAYOUT FINISH: BODY & PIN: MATERIAL: PERFORMANCE: IMPEDANCE: OPERATING TEMP.: SV P/N 3811-60005 3811-60006 GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. 50 OHMS. -55 C TO +125 C. NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com FINISH: SEE NOTES SEE NOTES SURFACE AREA: N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: ELA 05/19/16 CHECKED: APPROVED: DAL 05/19/16 DAL 05/19/16 INTERFACE SMOOTH BORE FULL DETENT 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMPS MALE SURFACE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 30:1 3811-60005-60006-TD SHEET 1 OF 1
3811-60005-TD 价格&库存
很抱歉,暂时无法提供与“3811-60005-TD”相匹配的价格&库存,您可以联系我们找货
3811-60005-TD
    库存:5
