9311-60037
9311-60037
    AMPHENOLSVMICROWAVE(安费诺MAO)
    CONNSMPPLUGSTR50OHMEDGEMNT
9311-60037 数据手册
ROHS COMPLIANT PRODUCT DATA DRAWING REVISION HISTORY DESCRIPTION REV 4X DATE APPROVED - DCN 38478 08/11 STW A NRN 40651 05/16 STW .165 4.19 RP .140 3.56 .290 7.37 .090 2.29 .230 5.84 .180 4.57 9X .090 2.29 2X .065 1.65 4X SV P/N 9311-60036 9311-60037 9311-60038 4X .160 4.06 3X .040 1.02 .015 0.38 INTERFACE SMOOTH BORE LIMITED DETENT FULL DETENT .890 22.61 .104 2.63 .192 4.88 MATERIAL: 5X .015 0.38 BODY & SHROUDS: STAINLESS STEEL PER AMS-5640, ALLOY UNS S30300, TYPE 1 CONTACTS: BERYLLIUM COPPER PER ASTM B196, ALLOY No. UNS C17300, TD04 INSULATORS: PTFE PER ASTM D1710, TYPE I, GRADE 1, CLASS B 3X .200±.002 5.08±0.05 2X .100 2.54 .800±.004 20.32±0.10 FINISH: BODY, SHROUDS & CONTACTS: GOLD PER ASTM B488, TYPE II, CODE C, CLASS 1.27, OVER NICKEL PER AMS-QQ-N-290, CLASS 1, .00005" MIN. NOTES: 1. FOR A FOOTPRINT RECOMMENDATION SPECIFIC TO YOUR PCB, PLEASE CONTACT US AT applications@svmicro.com MATERIAL: FINISH: PERFORMANCE: SEE NOTES SEE NOTES SURFACE AREA: IMPEDANCE: FREQ. RANGE: 50 OHMS DC TO 26.5 GHz. N/A PROPRIETARY THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SV MICROWAVE, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SV MICROWAVE, INC IS PROHIBITED. DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL: DECIMAL: .X .XX .XXX 1/64 ANGULAR: X X X' 1 0' 15' .030 .010 .005 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5M - 1994 THIRD ANGLE PROJECTION SV Microwave, Inc. UNLESS OTHERWISE SPECIFIED 1) ALL DIMENSIONS ARE IN INCHES [MILLIMETERS] 2) ALL DIMENSIONS ARE AFTER PLATING. 3) BREAK CORNERS & EDGES .005 R. MAX. 4) CHAM. 1ST & LAST THREADS. 5) SURFACE ROUGHNESS 63 e MIL-STD-10. 6) DIA.’S ON COMMON CENTERS TO BE CONCENTRIC WITHIN .005 T.I.R. 7) REMOVE ALL BURRS DRAWN: FSG 08/18/11 CHECKED: APPROVED: STW 08/18/11 STW 08/18/11 2400 Centrepark West Drive, Suite 100 West Palm Beach, FL 33409 TITLE: SMP MALE 4-PORT PCB EDGE MOUNT SIZE CAGE CODE DWG. NO. B 95077 SCALE: 7:1 9311-60036-60038 SHEET 1 OF 1
9311-60037 价格&库存
很抱歉,暂时无法提供与“9311-60037”相匹配的价格&库存,您可以联系我们找货
  • 25+950.3671625+122.94450
  • 50+896.7167550+116.00400
库存:125
9311-60037
  • 25+934.0751525+120.83688
  • 50+881.3444650+114.01536
库存:125
